Group: DynoMotion Message: 5031 From: mattbsemail Date: 5/22/2012
Subject: How many Axis' will KFlop w/ Kanalog support?
I'm looking at running Kflop with Kanalog on my mill with a haas 4th axis. All the motors are 24VDC servo motors. I also wanted to have rigid tapping capabilities. What exactly does that require besides a spindle encoder? Will it be able to control my tool changer? The last question I can think of was... How difficult is the C programming stuff? My mill is a Kasuga with a bandit control and a quick draw tool changer.
Thank you for your time,
Matt
Group: DynoMotion Message: 5033 From: mattbsemail Date: 5/22/2012
Subject: Re: How many Axis' will KFlop w/ Kanalog support?
My fault I'm unsure of the 4th axis voltage but the other 3 are summit dana DC servo motors 90V 74A 1430RPM
> Matt
Group: DynoMotion Message: 5038 From: Tom Kerekes Date: 5/23/2012
Hi Matt,
You will need amplifiers that go between Kanalog and your Amplifiers.
To do Rigid Tapping you will need an encoder on the spindle so that the Z axis can track the spindle motion.  The Spindle Amplifier will also need to be controllable in a way that it can rotate at a reasonable tapping RPM for a specified number of rotations, then reverse for a specified number of rotations.  If your spindle is driven by a servo amplifier this is straightforward.  If it is a more basic VFD it can be more challenging.  User Bengt has been posting regarding this.
For a tool changer you will need to program the tool change sequence for your system.
If you have any understanding of writing programs the C programming should be straight forward, otherwise it will be difficult.
Group: DynoMotion Message: 5042 From: mattbsemail Date: 5/23/2012
Thanks for the reply Tom!
Yeah I was planning on running a encoder off the top of the tool changer drawbar deal for the my spindle. I don't have a VFD yet but I plan on getting one once I know what I need. Currently it has a 5Hp 3 phase 220V or something. I just don't understand the soft start and multiple start thing.
I'm the only person in the CNC department at my shop so writing programs is no big deal.
You said I need amplifiers. Which amplifiers and encoders do u recommend? I was reading on your site and I saw the axis page. It appears to be able to support 8 axis' and encoders? 0-7
I'll do some searching to read up more on the rigid tapping w/ VFD.
> Hi Matt,
> From: mattbsemail <mattbsemail@...>
> Sent: Tuesday, May 22, 2012 8:15 PM
> Subject: [DynoMotion] How many Axis' will KFlop w/ Kanalog support?
> Matt
